Salta al contenuto principale
Acer Chromebook CB3-431-C5EX Motherboard Replacement
Cosa ti serve
  1. Acer Chromebook CB3-431-C5EX Motherboard Replacement, Bottom Panel: passo 1, immagine 1 di 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Motherboard Replacement: passo 3, immagine 1 di 2 Acer Chromebook CB3-431-C5EX Motherboard Replacement: passo 3, immagine 2 di 2
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Motherboard Replacement, Battery: passo 4, immagine 1 di 1
    • Remove the two 4mm Phillips #0 screws on either side of the battery pack that are securing it in place.
  5. Acer Chromebook CB3-431-C5EX Motherboard Replacement: passo 5, immagine 1 di 2 Acer Chromebook CB3-431-C5EX Motherboard Replacement: passo 5, immagine 2 di 2
    • Disconnect the taped white 8-pin cable on the bottom right of the battery pack.
    • Use thumbnail to pull on the small protruding tabs on either side of the connector.
  6. Acer Chromebook CB3-431-C5EX Motherboard Replacement: passo 6, immagine 1 di 1
    • Carefully lift the entire battery pack out of the laptop.
  7. Acer Chromebook CB3-431-C5EX Motherboard Replacement, Motherboard: passo 7, immagine 1 di 2 Acer Chromebook CB3-431-C5EX Motherboard Replacement, Motherboard: passo 7, immagine 2 di 2
    • Remove the 4.7 mm screw from the Wi-Fi card using a Phillips #0 screwdriver.
    • Remove the Wi-Fi card from the laptop.
  8. Acer Chromebook CB3-431-C5EX Motherboard Replacement: passo 8, immagine 1 di 2 Acer Chromebook CB3-431-C5EX Motherboard Replacement: passo 8, immagine 2 di 2
    • Unplug the black wire connecting the small circuit board to the motherboard.
  9. Acer Chromebook CB3-431-C5EX Motherboard Replacement: passo 9, immagine 1 di 3 Acer Chromebook CB3-431-C5EX Motherboard Replacement: passo 9, immagine 2 di 3 Acer Chromebook CB3-431-C5EX Motherboard Replacement: passo 9, immagine 3 di 3
    • Lift the respective white and black tabs and slide the ribbon cables out of their connectors.
  10. Acer Chromebook CB3-431-C5EX Motherboard Replacement: passo 10, immagine 1 di 2 Acer Chromebook CB3-431-C5EX Motherboard Replacement: passo 10, immagine 2 di 2
    • Carefully remove the display adapter from the motherboard.
  11. Acer Chromebook CB3-431-C5EX Motherboard Replacement: passo 11, immagine 1 di 2 Acer Chromebook CB3-431-C5EX Motherboard Replacement: passo 11, immagine 2 di 2
    • Remove the black tab connecting the motherboard to the keyboard.
  12. Acer Chromebook CB3-431-C5EX Motherboard Replacement: passo 12, immagine 1 di 2 Acer Chromebook CB3-431-C5EX Motherboard Replacement: passo 12, immagine 2 di 2
    • Remove the five 4.7 mm screws from the motherboard using a Phillips #0 screwdriver.
    • Remove the two 4.5 mm screws from the motherboard using a Phillips #0 screwdriver.
    • Gently remove motherboard from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 476
