Salta al contenuto principale
Acer Chromebook CB3-431-C5EX Battery Replacement
Cosa ti serve
  1. Acer Chromebook CB3-431-C5EX Battery Replacement, Bottom Panel: passo 1, immagine 1 di 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Battery Replacement: passo 2, immagine 1 di 1
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Battery Replacement: passo 3, immagine 1 di 2 Acer Chromebook CB3-431-C5EX Battery Replacement: passo 3, immagine 2 di 2
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Battery Replacement, Battery: passo 4, immagine 1 di 1
    • Remove the two 4mm Phillips #0 screws on either side of the battery pack that are securing it in place.
  5. Acer Chromebook CB3-431-C5EX Battery Replacement: passo 5, immagine 1 di 2 Acer Chromebook CB3-431-C5EX Battery Replacement: passo 5, immagine 2 di 2
    • Disconnect the taped white 8-pin cable on the bottom right of the battery pack.
    • Use thumbnail to pull on the small protruding tabs on either side of the connector.
  6. Acer Chromebook CB3-431-C5EX Battery Replacement: passo 6, immagine 1 di 1
    • Carefully lift the entire battery pack out of the laptop.
Conclusione
Altre 7 persone hanno completato questa guida.
Elsa Bassett
Membro da: 04/18/17
414 Reputazione
1 Guida realizzata
Cal Poly, Team S17-G3, Banghart Spring 2017 Membro di Cal Poly, Team S17-G3, Banghart Spring 2017
CPSU-BANGHART-S17S17G3
5 Membri
10 Guide realizzate
2 Commenti
A heat gun is listed as a need tool, but the instructions do not mention using it.
Medium strength (blue) threadlocker compound should be used during reassembly.
Stephen Gertsch - Replica
why didnt it stop giving instruction I think I got the wrong battery pak no more acer for me acer 14 they dont know what batterty to send you what a joke LOL
woody wilson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 63
Tutti i Tempi: 8,590
