Salta al contenuto principale
Acer Chromebook CB3-131-C3KD Track pad Replacement
Cosa ti serve
  1. Acer Chromebook CB3-131-C3KD Track pad Replacement, Battery: passo 1, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Track pad Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure you turn off the laptop before starting.
    • Unscrew and remove the (11) eleven 4mm J0 head screws on the underside of the laptop using the JIS #0 screwdriver.
  2. Acer Chromebook CB3-131-C3KD Track pad Replacement: passo 2, immagine 1 di 3 Acer Chromebook CB3-131-C3KD Track pad Replacement: passo 2, immagine 2 di 3 Acer Chromebook CB3-131-C3KD Track pad Replacement: passo 2, immagine 3 di 3
    • Use the plastic opening tool to remove the back cover.
    • Be careful not to damage the ribbon cable connecting the back cover to the laptop.
  3. Acer Chromebook CB3-131-C3KD Track pad Replacement: passo 3, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Track pad Replacement: passo 3, immagine 2 di 2
    • Unscrew the (2) two 3mm J0 Phillips head screws that hold the battery in place.
  4. Acer Chromebook CB3-131-C3KD Track pad Replacement: passo 4, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Track pad Replacement: passo 4, immagine 2 di 2
    • Disconnect the battery from the motherboard.
    • Carefully disconnect the cable parallel to the board, not at an angle. Otherwise, you could damage the port.
  5. Acer Chromebook CB3-131-C3KD Track pad Replacement: passo 5, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Track pad Replacement: passo 5, immagine 2 di 2
    • Carefully lift the battery from one side, and then lift it out of the laptop.
  6. Acer Chromebook CB3-131-C3KD Track pad Replacement, Trackpad: passo 6, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Track pad Replacement, Trackpad: passo 6, immagine 2 di 2
    • Remove the (3) three 7.0mm screws using the J0 screwdriver head.
  7. Acer Chromebook CB3-131-C3KD Track pad Replacement: passo 7, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Track pad Replacement: passo 7, immagine 2 di 2
    • Unlock the latches on both ends of the ribbon cable, and pull to detach.
    • The ribbon cable will still be attached to the tape.
  8. Acer Chromebook CB3-131-C3KD Track pad Replacement: passo 8, immagine 1 di 1
    • Peel the tape that is on top of the trackpad.
  9. Acer Chromebook CB3-131-C3KD Track pad Replacement: passo 9, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Track pad Replacement: passo 9, immagine 2 di 2
    • Lift the trackpad out of the Chromebook.
Conclusione
USF Tampa, Team S11-G1, Passmore Fall 2017 Membro di USF Tampa, Team S11-G1, Passmore Fall 2017
USFT-PASSMORE-F17S11G1
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 420
