Salta al contenuto principale
Acer Chromebook CB3-131-C3KD Speakers Replacement
Cosa ti serve
  1. Acer Chromebook CB3-131-C3KD Speakers Replacement, Battery: passo 1, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Speakers Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure you turn off the laptop before starting.
    • Unscrew and remove the (11) eleven 4mm J0 head screws on the underside of the laptop using the JIS #0 screwdriver.
  2. Acer Chromebook CB3-131-C3KD Speakers Replacement: passo 2, immagine 1 di 3 Acer Chromebook CB3-131-C3KD Speakers Replacement: passo 2, immagine 2 di 3 Acer Chromebook CB3-131-C3KD Speakers Replacement: passo 2, immagine 3 di 3
    • Use the plastic opening tool to remove the back cover.
    • Be careful not to damage the ribbon cable connecting the back cover to the laptop.
  3. Acer Chromebook CB3-131-C3KD Speakers Replacement: passo 3, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Speakers Replacement: passo 3, immagine 2 di 2
    • Unscrew the (2) two 3mm J0 Phillips head screws that hold the battery in place.
  4. Acer Chromebook CB3-131-C3KD Speakers Replacement: passo 4, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Speakers Replacement: passo 4, immagine 2 di 2
    • Disconnect the battery from the motherboard.
    • Carefully disconnect the cable parallel to the board, not at an angle. Otherwise, you could damage the port.
  5. Acer Chromebook CB3-131-C3KD Speakers Replacement: passo 5, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Speakers Replacement: passo 5, immagine 2 di 2
    • Carefully lift the battery from one side, and then lift it out of the laptop.
  6. Acer Chromebook CB3-131-C3KD Speakers Replacement, Speakers: passo 6, immagine 1 di 3 Acer Chromebook CB3-131-C3KD Speakers Replacement, Speakers: passo 6, immagine 2 di 3 Acer Chromebook CB3-131-C3KD Speakers Replacement, Speakers: passo 6, immagine 3 di 3
    • Disconnect the three ribbon cables from the motherboard.
  7. Acer Chromebook CB3-131-C3KD Speakers Replacement: passo 7, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Speakers Replacement: passo 7, immagine 2 di 2
    • Unplug the cable by putting both thumbs on each tab and unlocking the cable by pushing the tabs away.
  8. Acer Chromebook CB3-131-C3KD Speakers Replacement: passo 8, immagine 1 di 3 Acer Chromebook CB3-131-C3KD Speakers Replacement: passo 8, immagine 2 di 3 Acer Chromebook CB3-131-C3KD Speakers Replacement: passo 8, immagine 3 di 3
    • Remove speakers by placing index finger on top and thumb on bottom of the speakers.
    • Peel speakers away from the base that is connected by an adhesive.
  9. Acer Chromebook CB3-131-C3KD Speakers Replacement: passo 9, immagine 1 di 3 Acer Chromebook CB3-131-C3KD Speakers Replacement: passo 9, immagine 2 di 3 Acer Chromebook CB3-131-C3KD Speakers Replacement: passo 9, immagine 3 di 3
    • Peel the black cord connecting the two speakers together away from the Velcro located at the midpoint between the two speakers.
    • Remove speakers from laptop.
Conclusione
Johnathan
Membro da: 09/26/17
216 Reputazione
2 Guide realizzate
USF Tampa, Team S11-G1, Passmore Fall 2017 Membro di USF Tampa, Team S11-G1, Passmore Fall 2017
USFT-PASSMORE-F17S11G1
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 333
