Salta al contenuto principale
Acer Chromebook CB3-131-C3KD Motherboard Replacement
Cosa ti serve
  1. Acer Chromebook CB3-131-C3KD Motherboard Replacement, Battery: passo 1, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure you turn off the laptop before starting.
    • Unscrew and remove the (11) eleven 4mm J0 head screws on the underside of the laptop using the JIS #0 screwdriver.
  2. Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 2, immagine 1 di 3 Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 2, immagine 2 di 3 Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 2, immagine 3 di 3
    • Use the plastic opening tool to remove the back cover.
    • Be careful not to damage the ribbon cable connecting the back cover to the laptop.
  3. Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 3, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 3, immagine 2 di 2
    • Unscrew the (2) two 3mm J0 Phillips head screws that hold the battery in place.
  4. Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 4, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 4, immagine 2 di 2
    • Disconnect the battery from the motherboard.
    • Carefully disconnect the cable parallel to the board, not at an angle. Otherwise, you could damage the port.
  5. Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 5, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 5, immagine 2 di 2
    • Carefully lift the battery from one side, and then lift it out of the laptop.
  6. Acer Chromebook CB3-131-C3KD Motherboard Replacement, Motherboard: passo 6, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Motherboard Replacement, Motherboard: passo 6, immagine 2 di 2
    • Unscrew the (4) four J0 head 3.0 mm screws from the motherboard.
    • Unscrew the (1) one 7.0 mm screw from the center of the motherboard.
  7. Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 7, immagine 1 di 3 Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 7, immagine 2 di 3 Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 7, immagine 3 di 3
    • Unlock the latches on the three white ribbon cables, then pull to detach them from the motherboard.
    • Slide the hook forward and pull the black ribbon cable out.
  8. Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 8, immagine 1 di 3 Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 8, immagine 2 di 3 Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 8, immagine 3 di 3
    • Unscrew the 4.0 mm screw from the Wi-fi card using the JIS #0 screwdriver.
    • Pull the Wi-fi card parallel to the Chromebook to remove.
  9. Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 9, immagine 1 di 3 Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 9, immagine 2 di 3 Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 9, immagine 3 di 3
    • To remove the regular cable near the hinge, pry from one side.
    • To remove the regular cable at the top of the motherboard, pull it parallel to the board.
  10. Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 10, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Motherboard Replacement: passo 10, immagine 2 di 2
    • Open the hinge by prying it backwards.
    • Remove the motherboard by lifting from the top.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S11-G1, Passmore Fall 2017 Membro di USF Tampa, Team S11-G1, Passmore Fall 2017
USFT-PASSMORE-F17S11G1
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,216
