Salta al contenuto principale
Acer Chromebook CB3-131-C3KD Keyboard Key Replacement
Cosa ti serve
  1. Acer Chromebook CB3-131-C3KD Keyboard Key Replacement, Keyboard Key: passo 1, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Keyboard Key Replacement, Keyboard Key: passo 1, immagine 2 di 2
    • Make sure you turn off the laptop before starting.
    • Place the flat head screw driver under the key, but over the key clip retainer.
  2. Acer Chromebook CB3-131-C3KD Keyboard Key Replacement: passo 2, immagine 1 di 1
    • Push down on one of the bottom corners of the key, so that the opposite diagonal corner rises and gives leeway.
    • Carefully place the flat head screw driver under the raised corner.
    • Carefully pry up from underneath the raised corner to raise the metal clips away from the key base.
  3. Acer Chromebook CB3-131-C3KD Keyboard Key Replacement: passo 3, immagine 1 di 2 Acer Chromebook CB3-131-C3KD Keyboard Key Replacement: passo 3, immagine 2 di 2
    • Pry up from the top left and right corners of the retainer subsequently.
    • Remove clip retainer.
Conclusione
Johnathan
Membro da: 09/26/17
216 Reputazione
2 Guide realizzate
USF Tampa, Team S11-G1, Passmore Fall 2017 Membro di USF Tampa, Team S11-G1, Passmore Fall 2017
USFT-PASSMORE-F17S11G1
3 Membri
10 Guide realizzate
Un commento
I mean… That’s half of the replacement… so there’s that.
Darren D. MacDonald - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,475
