Salta al contenuto principale
Acer Chromebook CB3-111-C8UB Key Replacement
Cosa ti serve
  1. Acer Chromebook CB3-111-C8UB Key  Replacement, Key: passo 1, immagine 1 di 3 Acer Chromebook CB3-111-C8UB Key  Replacement, Key: passo 1, immagine 2 di 3 Acer Chromebook CB3-111-C8UB Key  Replacement, Key: passo 1, immagine 3 di 3
    • Slide the plastic opening tool under the key you wish to remove until it is up against the bottom part of the key.
    • Then, lever the plastic opening tool. It should catch the key.
    • Finally, keep levering the key until it pops out.
    • We do this to avoid depressing the key. It becomes much harder to catch the lip with the key pushed down.
Conclusione
To put the key back in place, simply push down on it until you hear the clips snap into place.
Travis Vo
Membro da: 01/27/17
426 Reputazione
4 Guide realizzate
Cal Poly, Team 22-7, Maness Winter 2017 Membro di Cal Poly, Team 22-7, Maness Winter 2017
CPSU-MANESS-W17S22G7
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 25
Tutti i Tempi: 514
