Salta al contenuto principale
Acer Chromebook CB3-111-C8UB Back Panel Removal
Cosa ti serve
  1. Acer Chromebook CB3-111-C8UB Back Panel Removal, Back Panel Removal: passo 1, immagine 1 di 2 Acer Chromebook CB3-111-C8UB Back Panel Removal, Back Panel Removal: passo 1, immagine 2 di 2
    • Position the laptop upside down with the hinges on the side furthest away from you.
    • Remove the eight 8mm screws with a phillips #1 screwdriver,
    • Remove the four 4.5mm screws with a phillips #1 screwdriver,
  2. Acer Chromebook CB3-111-C8UB Back Panel Removal: passo 2, immagine 1 di 3 Acer Chromebook CB3-111-C8UB Back Panel Removal: passo 2, immagine 2 di 3 Acer Chromebook CB3-111-C8UB Back Panel Removal: passo 2, immagine 3 di 3
    • There is a wire connecting the two pieces of the laptop, from the inside, on the left, be careful not to damage it.
    • Use the plastic opening tool to pry open then remove the plastic base from the rest of the laptop. Start from the right side and work towards the left.
    • Set the plastic base beside the laptop by opening it as if you were opening a book.
  3. Acer Chromebook CB3-111-C8UB Back Panel Removal: passo 3, immagine 1 di 2 Acer Chromebook CB3-111-C8UB Back Panel Removal: passo 3, immagine 2 di 2
    • Flip up the small white ZIF connector by using a fingernail or metal spudger.
    • Pull the blue tab to remove the ribbon cable.
    • The ribbon cable is adhered to the plastic so it will take a little bit of force to remove it.
Conclusione
Travis Vo
Membro da: 01/27/17
426 Reputazione
4 Guide realizzate
Cal Poly, Team 22-7, Maness Winter 2017 Membro di Cal Poly, Team 22-7, Maness Winter 2017
CPSU-MANESS-W17S22G7
4 Membri
12 Guide realizzate
Un commento
When I removed the screws from the bottom (Step 1), the 8 screws closest to the hinge were 7mm, and the front 4 were 5mm. Hope this helps someone in the future.
lumberjackdavid - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,791
