Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Use this guide to replace the screen of your Acer Chromebook CB3-111-C670. The screen replacement is a simple fix, and shouldn't take long at all.
  1. Unplug and power off the laptop before starting this repair. Pry the white frame away from the screen with an opening tool.
    • Unplug and power off the laptop before starting this repair.
    • Pry the white frame away from the screen with an opening tool.
    • As you move the spudger along the seam between the frame and the screen, the clips holding the frame in place will loosen.
  2. Remove the four screws within the silver brackets that are holding the screen to the back of the laptop. Remove the four screws within the silver brackets that are holding the screen to the back of the laptop.
    • Remove the four screws within the silver brackets that are holding the screen to the back of the laptop.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Once you've removed the screws, lift the piece of tape that is covering the display connector.
    • Once you've removed the screws, lift the piece of tape that is covering the display connector.
    • Use a spudger to flip up the black tab on top of the connector to unlock the ZIF connector.
  5. Pull the ribbon cable out with tweezers and remove the screen.
    • Pull the ribbon cable out with tweezers and remove the screen.
Conclusione
Altre 9 persone hanno completato questa guida.
Allen Lewis
Membro da: 20/01/2016
256 Reputazione
1 Guida realizzata
USF Tampa, Team 10-5, Remmell Spring 2016 Membro di USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
3 Membri
8 Guide realizzate
Very easy. Thanks
johnqm123 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 50
Tutti i Tempi: 3,995
