Salta al contenuto principale
Acer Chromebook CB3-111-C670 Keyboard Key Replacement
Cosa ti serve
  1. Acer Chromebook CB3-111-C670 Keyboard Key Replacement, Keyboard Key: passo 1, immagine 1 di 1
    • Remove broken key(s) using the flat end of spudger.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular spudger and tweezer should be used whenever possible.
    • When reinstalling the key, no spudger is needed. Just pop it into place with fingers.
  2. Acer Chromebook CB3-111-C670 Keyboard Key Replacement: passo 2, immagine 1 di 2 Acer Chromebook CB3-111-C670 Keyboard Key Replacement: passo 2, immagine 2 di 2
    • Using the flat end of the spudger, very carefully lift up the corners of the cradle.
    • With the help of tweezers (needle nose works best), pull the hooks of the cradle out.
    • For re-installation of the plastic piece use tweezers to put it back in place and pop the bottom half in before the top.
Conclusione
Altre 4 persone hanno completato questa guida.
Tony
Membro da: 01/20/16
459 Reputazione
2 Guide realizzate
USF Tampa, Team 10-5, Remmell Spring 2016 Membro di USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
3 Membri
8 Guide realizzate
Un commento
no help i need help putting it on with out that
Simon Kuhn - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 92
Tutti i Tempi: 7,230
