Salta al contenuto principale
Acer Chromebook C740-C4PE Solid State Drive Replacement
Cosa ti serve
  1. Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: passo 1, immagine 1 di 3 Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: passo 1, immagine 2 di 3 Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: passo 1, immagine 3 di 3
    • Make sure the laptop is turned off and laid down on a flat surface.
    • Unscrew the 13 screws on the back of the device using a PH0 Phillips head screwdriver.
    • Use the spudger or any other prying tool to pry the back plate off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Solid State Drive Replacement: passo 2, immagine 1 di 3 Acer Chromebook C740-C4PE Solid State Drive Replacement: passo 2, immagine 2 di 3 Acer Chromebook C740-C4PE Solid State Drive Replacement: passo 2, immagine 3 di 3
    • Remove the 3.75 mm screw with a Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Solid State Drive Replacement: passo 3, immagine 1 di 1
    • Pull the Solid State Drive out of the connector.
Conclusione
Sang Huynh
Membro da: 03/08/17
252 Reputazione
2 Guide realizzate
1Commento della guida
There are 2 types of SSD drives, m-SATA and M.2. Which does C740 use?
Guy Scree - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 41
Tutti i Tempi: 907
