Introduzione
This guide will demonstrate how to partially take apart the Acer Chromebook C740-C4PE, in addition to removing the heatsink.
Parti
Nessuna parte richiesta.
  1. Make sure the laptop is turned off and laid down on a flat surface. Unscrew the thirteen  10mm screws on the back of the device using a Phillips #0 screwdriver. Use the spudger or any other prying tool to pry the back plate off of the device.
    • Make sure the laptop is turned off and laid down on a flat surface.
    • Unscrew the thirteen 10mm screws on the back of the device using a Phillips #0 screwdriver.
    • Use the spudger or any other prying tool to pry the back plate off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Remove the four 5mm  screws on the heatsink using the Phillips #0 screwdriver. Remove the four 5mm  screws on the heatsink using the Phillips #0 screwdriver.
    • Remove the four 5mm screws on the heatsink using the Phillips #0 screwdriver.
  3. Loosen the two Phillips-head screws on the fan attached to the heatsink. Loosen the two Phillips-head screws on the fan attached to the heatsink.
    • Loosen the two Phillips-head screws on the fan attached to the heatsink.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Detach the two antennae cables from the  WiFi card by gently pulling on them.
    • Detach the two antennae cables from the WiFi card by gently pulling on them.
  6. Gently pull the fan cable out of the motherboard.
    • Gently pull the fan cable out of the motherboard.
    • Pulling too hard may break the wires or the connector itself.
  7. Remove the cable routed through the fan.
    • Remove the cable routed through the fan.
    • Do not completely remove the cables as they are attached to the motherboard. Once they are no longer routed in the fan, leave them as they are.
  8. Remove the heatsink from the motherboard.
    • Remove the heatsink from the motherboard.
    • Before changing the heatsink/fan, you must clean off the thermal paste from the CPU and apply new thermal paste.
Conclusione
Dylan Tocci
Membro da: 17/10/2017
237 Reputazione
2 Guide realizzate
What type of thermal paste is best used?
Tracey Arria - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 94
