Salta al contenuto principale
Acer Chromebook C740-C4PE Battery Replacement
Cosa ti serve
  1. Acer Chromebook C740-C4PE Battery Replacement, Battery: passo 1, immagine 1 di 3 Acer Chromebook C740-C4PE Battery Replacement, Battery: passo 1, immagine 2 di 3 Acer Chromebook C740-C4PE Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure the laptop is turned off and unplugged before starting.
    • Unscrew the thirteen 10mm screws on the back of the computer using the Phillips #0 screwdriver.
    • Using the spudger or other prying tool, gently pry the back off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Battery Replacement: passo 2, immagine 1 di 1
    • Unscrew the two 5mm battery screws using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Battery Replacement: passo 3, immagine 1 di 1
    • Gently lift the battery up and away from the hooks on the bottom of the device keeping the battery in place.
    • Be sure the battery is away from the clips before pulling away so as not to break the clips.
  4. Acer Chromebook C740-C4PE Battery Replacement: passo 4, immagine 1 di 3 Acer Chromebook C740-C4PE Battery Replacement: passo 4, immagine 2 di 3 Acer Chromebook C740-C4PE Battery Replacement: passo 4, immagine 3 di 3
    • Detach the connecting cable from the motherboard by pulling away.
    • Remove the battery from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
Jacob Kahn
Membro da: 10/17/17
273 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 533
