Salta al contenuto principale
Acer Chromebook C740 LCD Screen Replacement
Cosa ti serve
  1. Acer Chromebook C740 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 1
    • Power down the Chromebook and disconnect the power adapter.
  2. Acer Chromebook C740 LCD Screen Replacement: passo 2, immagine 1 di 2 Acer Chromebook C740 LCD Screen Replacement: passo 2, immagine 2 di 2
    • With the Chromebook open and face up, pry the black screen frame with your fingers.
    • Move slowly around the display to evenly remove it.
    • Clicking sounds indicate the panel is seperating from the overall display.
  3. Acer Chromebook C740 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Once the frame is separated from the display, angle the display assembly back .
    • Lift up the portions of the frame covering the front two hinges with the spudger.
  4. Acer Chromebook C740 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Remove the frame from the screen assembly by pulling the frame towards you.
    • Some adjustment of the display assembly may be needed so that the frame is not stuck near the hinges.
  5. Acer Chromebook C740 LCD Screen Replacement: passo 5, immagine 1 di 2 Acer Chromebook C740 LCD Screen Replacement: passo 5, immagine 2 di 2
    • Remove the six 3.35mm screws with a Phillips #0 Screwdriver.
  6. Acer Chromebook C740 LCD Screen Replacement: passo 6, immagine 1 di 3 Acer Chromebook C740 LCD Screen Replacement: passo 6, immagine 2 di 3 Acer Chromebook C740 LCD Screen Replacement: passo 6, immagine 3 di 3
    • Place the LCD screen face down on the keyboard.
    • Remove the tape holding the black connector in place.
    • Unplug the connector with your hands.
Conclusione
Altre 7 persone hanno completato questa guida.
Grace Bassett
Membro da: 04/26/17
217 Reputazione
1 Guida realizzata
Cal Poly, Team S22-G2, Livingston Spring 2017 Membro di Cal Poly, Team S22-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G2
4 Membri
12 Guide realizzate
Un commento
You actually don’t need to unscrew the middle screws, and you don’t need to buy a new bezel.
Keith Hudson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 3,308
