Salta al contenuto principale
Acer Chromebook C731-C8VE Wi-Fi Card Replacement
Cosa ti serve
  1. Acer Chromebook C731-C8VE Wi-Fi Card Replacement, Wi-Fi Card: passo 1, immagine 1 di 1
    • Place Chromebook face down.
  2. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: passo 2, immagine 1 di 2 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: passo 2, immagine 2 di 2
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2mm screws have washers and must be placed in these specific areas.
    • The 2mm screws marked orange do not have washers and will be placed on the left and right of the device.
  3. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: passo 3, immagine 1 di 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: passo 3, immagine 2 di 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: passo 3, immagine 3 di 3
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: passo 4, immagine 1 di 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: passo 4, immagine 2 di 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: passo 4, immagine 3 di 3
    • Detach the two wires that connect the Wi-Fi card to the screen.
    • The white wire will attach to the top and the black wire to the bottom.
  5. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: passo 5, immagine 1 di 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: passo 5, immagine 2 di 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: passo 5, immagine 3 di 3
    • Use the JIS #00 screwdriver to unscrew the single 1mm screw connecting the Wi-Fi card to the base.
    • Once the screw is removed, the Wi-Fi card will pop up.
  6. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: passo 6, immagine 1 di 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: passo 6, immagine 2 di 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: passo 6, immagine 3 di 3
    • Remove the Wi-Fi card from the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 172
