Salta al contenuto principale
Acer Chromebook C731-C8VE Trackpad Replacement
Cosa ti serve
  1. Acer Chromebook C731-C8VE Trackpad Replacement, Trackpad: passo 1, immagine 1 di 1
    • Place the Chromebook face down.
  2. Acer Chromebook C731-C8VE Trackpad Replacement: passo 2, immagine 1 di 1
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2 mm screws have washers and must be placed in these specific areas.
    • The 2 mm screws marked orange do not have washers attached and will be placed on the left and right of the device.
  3. Acer Chromebook C731-C8VE Trackpad Replacement: passo 3, immagine 1 di 3 Acer Chromebook C731-C8VE Trackpad Replacement: passo 3, immagine 2 di 3 Acer Chromebook C731-C8VE Trackpad Replacement: passo 3, immagine 3 di 3
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Trackpad Replacement: passo 4, immagine 1 di 3 Acer Chromebook C731-C8VE Trackpad Replacement: passo 4, immagine 2 di 3 Acer Chromebook C731-C8VE Trackpad Replacement: passo 4, immagine 3 di 3
    • Detach the wires connecting the keyboard and the touchpad to the motherboard by lifting the black connectors up.
  5. Acer Chromebook C731-C8VE Trackpad Replacement: passo 5, immagine 1 di 2 Acer Chromebook C731-C8VE Trackpad Replacement: passo 5, immagine 2 di 2
    • Use the JIS #00 screwdriver to remove four 1mm screws that connect the trackpad to the device.
  6. Acer Chromebook C731-C8VE Trackpad Replacement: passo 6, immagine 1 di 2 Acer Chromebook C731-C8VE Trackpad Replacement: passo 6, immagine 2 di 2
    • Do this step slowly to ensure that you do not damage the trackpad or the device.
    • Remove the trackpad from the base of the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 202
