Introduzione
If the speakers in your Acer Chromebook (model C731-C8VE) are sounding muddy, damaged, or just need an upgrade, this guide will help you replace the speaker assembly.
The speakers in this laptop use auxiliary power through the motherboard, and are attached with adhesive to the base of the laptop. A set of broken speakers in the laptop will result in sound that is muddy, distorted, or just plain no sound at all.
Before beginning this guide, you need to make sure that the power on your laptop is completely turned off since we will be removing the battery for this replacement.
Cosa ti serve
