Introduzione
If the keyboard has stopped working for your Acer Chromebook ( model C731-C8VE) this guide will help you with all of the steps you need to take to replace the keyboard assembly.
A broken keyboard can result in certain keys not registering, or none of the keys registering at all. If this is the case, its important to make sure you replace the keyboard in order to get your Chromebook up and working like new again!
Before starting on this repair, you need to make sure that the power on the laptop is completely turned off, especially since we will be removing the battery for this replacement.
Cosa ti serve
Use the JIS #00 Screwdriver to remove the four 0.5 mm screws holding the trackpad in order to detach it from the keyboard.
