Salta al contenuto principale
Acer Chromebook C731-C8VE Battery Replacement
Cosa ti serve
  1. Acer Chromebook C731-C8VE Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Place the Chromebook face down.
  2. Acer Chromebook C731-C8VE Battery Replacement: passo 2, immagine 1 di 1
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2 mm screws have washers and will be located on the left and right of the device.
    • The 2 mm screws marked orange do not have washers attached and must be placed in these specific areas.
  3. Acer Chromebook C731-C8VE Battery Replacement: passo 3, immagine 1 di 2 Acer Chromebook C731-C8VE Battery Replacement: passo 3, immagine 2 di 2
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Battery Replacement: passo 4, immagine 1 di 3 Acer Chromebook C731-C8VE Battery Replacement: passo 4, immagine 2 di 3 Acer Chromebook C731-C8VE Battery Replacement: passo 4, immagine 3 di 3
    • Detach the wires connecting the keyboard and the touchpad to the motherboard by lifting the black connectors up.
  5. Acer Chromebook C731-C8VE Battery Replacement: passo 5, immagine 1 di 3 Acer Chromebook C731-C8VE Battery Replacement: passo 5, immagine 2 di 3 Acer Chromebook C731-C8VE Battery Replacement: passo 5, immagine 3 di 3
    • Use the JIS #00 screwdriver to take out the 1mm screw that connects the battery to the base.
    • Detach the battery from the motherboard by lifting it up gently to avoid any damage to the motherboard.
  6. Acer Chromebook C731-C8VE Battery Replacement: passo 6, immagine 1 di 1
    • Remove the battery from the base of the device.
    • Do this step slowly to ensure that you do not damage the battery or the motherboard.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 386
