Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Use this guide to replace the battery in your device.
Parti
Nessuna parte specificata.
  1. Use a Phillips head screw driver to remove the 13 screws in these locations. Use a Phillips head screw driver to remove the 13 screws in these locations.
    • Use a Phillips head screw driver to remove the 13 screws in these locations.
  2. Use a plastic spudger to pry up the bottom cover and remove it. Be sure to pry along other edges if necessary to avoid damaging the back cover. Be sure to pry along other edges if necessary to avoid damaging the back cover.
    • Use a plastic spudger to pry up the bottom cover and remove it.
    • Be sure to pry along other edges if necessary to avoid damaging the back cover.
  3. Unscrew the 2 battery screws. Make sure you keep these screws separate from the back cover screws; they are different! Make sure you keep these screws separate from the back cover screws; they are different!
    • Unscrew the 2 battery screws.
    • Make sure you keep these screws separate from the back cover screws; they are different!
  4. Use two fingers to unplug the battery-to-motherboard connection. Use two fingers to unplug the battery-to-motherboard connection.
    • Use two fingers to unplug the battery-to-motherboard connection.
  5. Take out battery by lifting it up in the manner pictured.
    • Take out battery by lifting it up in the manner pictured.
Conclusione
Altre 8 persone hanno completato questa guida.
Robert Escobio
Membro da: 27/09/2017
567 Reputazione
4 Guide realizzate
USF Tampa, Team S9-G3, Remmell Fall 2017 Membro di USF Tampa, Team S9-G3, Remmell Fall 2017
USFT-REMMELL-F17S9G3
4 Membri
9 Guide realizzate
How do you know if the battery needs to be replaced
1910.julius - Replica
You will know if the battery needs to be replaced if your chromebook goes dead rather quickly than it used to or if you open it up and see that your bettery is bulged or appears to be inflated then if will also need to be replaced. I hope this helps.
Ashton Vandenbosch -
My Acer C720 Chromebook battery only charges to about 30-40% percent no matter how long I leave it on charger. Sometimes (randomly) it doesn’t charge at all. How do I diagnose whether I need to replace the charging port, the charging cord or the battery?
Bart Stinson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 44
Tutti i Tempi: 2,089
