Salta al contenuto principale
Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement
Cosa ti serve
  1. Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement, Heatsink and Cooling Fan: passo 1, immagine 1 di 1
    • Unscrew and remove the four 1 cm Phillips #00 screws from the heatsink.
  2. Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement: passo 2, immagine 1 di 1
    • Proceed to unscrew and remove the two 1 cm Phillips #00 screws holding the fan in place.
  3. Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement: passo 3, immagine 1 di 3 Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement: passo 3, immagine 2 di 3 Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement: passo 3, immagine 3 di 3
    • Remove the fan connection from the motherboard.
    • Disconnect the black & white cables.
    • Remove the cables from the hooks on the fan housing.
  4. Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement: passo 4, immagine 1 di 1
    • Lift up to remove the cooling fan and heatsink.
Conclusione
Gateway, Team 1-2, Pee Spring 2022 Membro di Gateway, Team 1-2, Pee Spring 2022
GCC-PEE-S22S1G2
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 124
