Salta al contenuto principale
Acer Chromebook C720-2844 Display Screen Replacement
Cosa ti serve
  1. Acer Chromebook C720-2844 Display Screen Replacement, Display Screen: passo 1, immagine 1 di 2 Acer Chromebook C720-2844 Display Screen Replacement, Display Screen: passo 1, immagine 2 di 2
    • Unscrew and remove the 1 cm Phillips #00 screws from motherboard.
  2. Acer Chromebook C720-2844 Display Screen Replacement: passo 2, immagine 1 di 2 Acer Chromebook C720-2844 Display Screen Replacement: passo 2, immagine 2 di 2
    • Unscrew and remove the 1 cm Phillips #00 screw that secures the solid state drive.
    • Lift and pull towards you to remove.
  3. Acer Chromebook C720-2844 Display Screen Replacement: passo 3, immagine 1 di 1
    • Disconnect the 3 cables shown by pulling back evenly from both ends.
  4. Acer Chromebook C720-2844 Display Screen Replacement: passo 4, immagine 1 di 2 Acer Chromebook C720-2844 Display Screen Replacement: passo 4, immagine 2 di 2
    • Unlock the cables shown by lifting the white tab on each.
    • Pull back on the blue tab to remove each cable from the motherboard.
  5. Acer Chromebook C720-2844 Display Screen Replacement: passo 5, immagine 1 di 2 Acer Chromebook C720-2844 Display Screen Replacement: passo 5, immagine 2 di 2
    • Remove the motherboard by shifting to the left and lifting up.
    • Unhook the black and white cables from underneath the motherboard.
  6. Acer Chromebook C720-2844 Display Screen Replacement: passo 6, immagine 1 di 1
    • Unscrew and remove the 1 cm Phillips #00 screws from the display brackets.
    • Lift bracket to detach from the screen.
  7. Acer Chromebook C720-2844 Display Screen Replacement: passo 7, immagine 1 di 1
    • Separate the screen from the shell.
Conclusione
Derek Zevalkink
Membro da: 02/10/22
145 Reputazione
1 Guida realizzata
Gateway, Team 1-2, Pee Spring 2022 Membro di Gateway, Team 1-2, Pee Spring 2022
GCC-PEE-S22S1G2
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 162
