Salta al contenuto principale
Acer Chromebook C720-2827 Trackpad Replacement
Cosa ti serve
  1. Acer Chromebook C720-2827 Trackpad Replacement, Back Panel Assembly: passo 1, immagine 1 di 2 Acer Chromebook C720-2827 Trackpad Replacement, Back Panel Assembly: passo 1, immagine 2 di 2
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 Trackpad Replacement: passo 2, immagine 1 di 2 Acer Chromebook C720-2827 Trackpad Replacement: passo 2, immagine 2 di 2
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 Trackpad Replacement, Battery: passo 3, immagine 1 di 1
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 Trackpad Replacement: passo 4, immagine 1 di 2 Acer Chromebook C720-2827 Trackpad Replacement: passo 4, immagine 2 di 2
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 Trackpad Replacement: passo 5, immagine 1 di 1
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 Trackpad Replacement, Trackpad: passo 6, immagine 1 di 3 Acer Chromebook C720-2827 Trackpad Replacement, Trackpad: passo 6, immagine 2 di 3 Acer Chromebook C720-2827 Trackpad Replacement, Trackpad: passo 6, immagine 3 di 3
    • Using a spudger, pry up the locking bar of the ZIF connector on the trackpad and remove the ribbon cable.
  7. Acer Chromebook C720-2827 Trackpad Replacement: passo 7, immagine 1 di 3 Acer Chromebook C720-2827 Trackpad Replacement: passo 7, immagine 2 di 3 Acer Chromebook C720-2827 Trackpad Replacement: passo 7, immagine 3 di 3
    • Peel off the clear plastic covering the screws.
    • Remove the five grey 2.5 mm screws securing the trackpad with a Phillips #1 screwdriver.
    • Remove another four silver 2.9mm Phillips #1 screws from the silver bracket atop the trackpad with your driver.
  8. Acer Chromebook C720-2827 Trackpad Replacement: passo 8, immagine 1 di 2 Acer Chromebook C720-2827 Trackpad Replacement: passo 8, immagine 2 di 2
    • Lift up the silver bracket.
    • Remove the trackpad by lifting it up from the case.
Conclusione
Austin Blakely
Membro da: 03/11/19
21.298 Reputazione
53 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.529 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 271
