Salta al contenuto principale
Acer Chromebook C720-2827 LED PCB Replacement
Cosa ti serve
  1. Acer Chromebook C720-2827 LED PCB Replacement, Back Panel Assembly: passo 1, immagine 1 di 2 Acer Chromebook C720-2827 LED PCB Replacement, Back Panel Assembly: passo 1, immagine 2 di 2
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 LED PCB Replacement: passo 2, immagine 1 di 2 Acer Chromebook C720-2827 LED PCB Replacement: passo 2, immagine 2 di 2
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 LED PCB Replacement, Battery: passo 3, immagine 1 di 1
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 LED PCB Replacement: passo 4, immagine 1 di 2 Acer Chromebook C720-2827 LED PCB Replacement: passo 4, immagine 2 di 2
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 LED PCB Replacement: passo 5, immagine 1 di 1
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: passo 6, immagine 1 di 3 Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: passo 6, immagine 2 di 3 Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: passo 6, immagine 3 di 3
    • Use the Phillips #1 screwdriver to remove the two 3.1mm screws from the LED PCB.
    • Lift the LED PCB up with your fingers and flip it over revealing the ZIF connector.
    • The LED PCB is still tethered to the daughterboard via a ribbon cable so be sure not to yank it out or it could cause damage to the cable or its connectors.
  7. Acer Chromebook C720-2827 LED PCB Replacement: passo 7, immagine 1 di 3 Acer Chromebook C720-2827 LED PCB Replacement: passo 7, immagine 2 di 3 Acer Chromebook C720-2827 LED PCB Replacement: passo 7, immagine 3 di 3
    • Set the LED PCB down and use your spudger to flip up the white bar of the ZIF connector.
    • Pull the ribbon cable out with your fingers.
Conclusione
Sarah Westberg
Membro da: 03/11/19
29.444 Reputazione
71 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.529 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 259
