Salta al contenuto principale
Introduzione
This guide will provide you with simple and clear steps on how to replace the motherboard on an Acer Chromebook C720-2420.
  1. Place your Chromebook upside down. Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Use the plastic opening tool to carefully remove the bottom.
    • Use the plastic opening tool to carefully remove the bottom.
  3. Remove the two 3.6 mm Phillips screws holding the battery in place. Remove the two 3.6 mm Phillips screws holding the battery in place.
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers. Alternatively, you could use your hands, as it may be difficult to unhook the connector.
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  5. Remove the battery.
    • Remove the battery.
  6. Remove the six 4.7 mm Phillips screws that secure the fan. Remove the six 4.7 mm Phillips screws that secure the fan.
    • Remove the six 4.7 mm Phillips screws that secure the fan.
  7. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  8. Disconnect these cables from the motherboard using the tweezers. Alternatively, you may use your hands. Pull out the fan.
    • Disconnect these cables from the motherboard using the tweezers.
    • Alternatively, you may use your hands.
    • Pull out the fan.
  9. Remove the 3.6 mm  Phillips screw that secures the SSD in place. Remove the 3.6 mm  Phillips screw that secures the SSD in place.
    • Remove the 3.6 mm Phillips screw that secures the SSD in place.
  10. Pull out the SSD. Pull out the SSD.
    • Pull out the SSD.
  11. Disconnect the speaker cable from the motherboard.
    • Disconnect the speaker cable from the motherboard.
  12. Disconnect the display cable from the motherboard.
    • Disconnect the display cable from the motherboard.
  13. Gently pull out the wire for the 2 PIC connectors.
    • Gently pull out the wire for the 2 PIC connectors.
  14. Remove the two 3.7 mm Phillips screws that hold the motherboard in place.
    • Remove the two 3.7 mm Phillips screws that hold the motherboard in place.
  15. Lift up the black tab on the ZIF connector to release the ribbon cable.
    • Lift up the black tab on the ZIF connector to release the ribbon cable.
    • Carefully remove the ribbon cable.
  16. Lift up the black tab on the ZIF connector to release the ribbon cable.
    • Gently remove the ribbon cable
  17. Lift up the black tab on the ZIF connector to release the ribbon cable.
    • Remove the ribbon cable.
  18. Lift up and remove the motherboard.
    • Lift up and remove the motherboard.
Conclusione
Josue Pardo
Membro da: 12/02/2018
181 Reputazione
1 Guida realizzata
USF Tampa, Team S15-G4, Boczar Spring 2018 Membro di USF Tampa, Team S15-G4, Boczar Spring 2018
USFT-BOCZAR-S18S15G4
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 75
