Salta al contenuto principale
Acer Chromebook C720-2420 Battery Replacement
Cosa ti serve
  1. Acer Chromebook C720-2420 Battery Replacement, Back Cover Replacement: passo 1, immagine 1 di 2 Acer Chromebook C720-2420 Battery Replacement, Back Cover Replacement: passo 1, immagine 2 di 2
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer Chromebook C720-2420 Battery Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer Chromebook C720-2420 Battery Replacement, Battery: passo 3, immagine 1 di 2 Acer Chromebook C720-2420 Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Acer Chromebook C720-2420 Battery Replacement: passo 4, immagine 1 di 2 Acer Chromebook C720-2420 Battery Replacement: passo 4, immagine 2 di 2
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  5. Acer Chromebook C720-2420 Battery Replacement: passo 5, immagine 1 di 1
    • Remove the battery.
Conclusione
USF Tampa, Team S15-G4, Boczar Spring 2018 Membro di USF Tampa, Team S15-G4, Boczar Spring 2018
USFT-BOCZAR-S18S15G4
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 540
