Salta al contenuto principale
Acer Chromebook C720-2103 Solid State Drive Replacement
Cosa ti serve
  1. Acer Chromebook C720-2103 Solid State Drive Replacement, Battery: passo 1, immagine 1 di 2 Acer Chromebook C720-2103 Solid State Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Shut the device off.
    • Turn the device over so the bottom is facing up.
    • Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
    • Remember to keep screws separated by step and their locations in the device. This will help prevent confusion during reassembly.
    • Removing the battery is necessary to prevent electric shock during part replacement.
  2. Acer Chromebook C720-2103 Solid State Drive Replacement: passo 2, immagine 1 di 1
    • Wedge a plastic opening tool between the back casing and the rest of the device.
    • Apply pressure up and down carefully, until backing pops up. Repeat this process in multiple spots if needed.
    • It is easiest to start at the back of the device, between the hinges of the screen.
    • Do not apply too much force. This will crack the plastic.
  3. Acer Chromebook C720-2103 Solid State Drive Replacement: passo 3, immagine 1 di 1
    • Remove the three 6mm screws indicated by the red circles with a Phillips #0 screwdriver.
  4. Acer Chromebook C720-2103 Solid State Drive Replacement: passo 4, immagine 1 di 2 Acer Chromebook C720-2103 Solid State Drive Replacement: passo 4, immagine 2 di 2
    • Pull the rainbow cable connector out of the white terminal by wiggling it gently from side to side with your fingers.
    • Be careful when removing the cable. Too much force can damage the motherboard or the cable connector.
  5. Acer Chromebook C720-2103 Solid State Drive Replacement: passo 5, immagine 1 di 2 Acer Chromebook C720-2103 Solid State Drive Replacement: passo 5, immagine 2 di 2
    • Lift the battery straight up and out of the device with your hands. Take care not to knock the battery against another component.
  6. Acer Chromebook C720-2103 Solid State Drive Replacement, Solid State Drive: passo 6, immagine 1 di 1
    • Remove one 6mm screw using a Phillips #0 screwdriver.
  7. Acer Chromebook C720-2103 Solid State Drive Replacement: passo 7, immagine 1 di 3 Acer Chromebook C720-2103 Solid State Drive Replacement: passo 7, immagine 2 di 3 Acer Chromebook C720-2103 Solid State Drive Replacement: passo 7, immagine 3 di 3
    • Carefully remove the solid state drive from the solid state drive slot by sliding it downward away from the motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
Matthew Holt
Membro da: 10/17/17
633 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 272
