Introduzione
Follow these simple steps to remove and replace a battery pack on an Acer Chromebook C720 with, a Philips #0 Screwdriver and plastic opening tool. Before beginning, be sure the device is completely drained, as it is dangerous to work on the device internals while the device is running. Also, remember to handle the device internals with care, as they are fragile and can be broken.
Cosa ti serve
Remove the thirteen 6mm screws using a Phillips #0 screwdriver.
Gently pry the back plate off using the plastic opening tool, leveraging the groove along the device's hinge.
Altre 4 persone hanno completato questa guida.
