Salta al contenuto principale
Acer Chromebook C710-2833 SD Card Reader Replacement
Cosa ti serve
  1. Acer Chromebook C710-2833 SD Card Reader Replacement, SD Card Reader: passo 1, immagine 1 di 1
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 2, immagine 1 di 2 Acer Chromebook C710-2833 SD Card Reader Replacement: passo 2, immagine 2 di 2
    • Remove the 6 mm Phillips #00 screw that holds the back cover on.
    • Carefully lift the cover off.
    • Place the cover and screw safely to the side for now.
  3. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 3, immagine 1 di 1
    • Using the spudger or your finger, slide the battery release slider and hold in place as shown.
    • When reassembling, holding of the slider is not needed.
  4. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 4, immagine 1 di 1
    • While holding the slider, pull out the old battery.
  5. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 5, immagine 1 di 3 Acer Chromebook C710-2833 SD Card Reader Replacement: passo 5, immagine 2 di 3 Acer Chromebook C710-2833 SD Card Reader Replacement: passo 5, immagine 3 di 3
    • Remove the two 3 mm Phillips #00 screws located on the WiFi card.
    • Pop the wires off the WiFi card.
    • Tilt the WiFi card up and remove it by pulling.
  6. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 6, immagine 1 di 1
    • Remove the fifteen 6 mm Phillips #00 screws holding on the plastic backing panel.
    • Remove the five 3 mm Phillips #00 screws holding on the plastic backing panel.
  7. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 7, immagine 1 di 3 Acer Chromebook C710-2833 SD Card Reader Replacement: passo 7, immagine 2 di 3 Acer Chromebook C710-2833 SD Card Reader Replacement: passo 7, immagine 3 di 3
    • Use the opening tool to pull the tabs back for the ribbon cable of the Solid State Drive.
    • Gently pull the ribbon cable out.
    • Remove the Solid State Drive.
  8. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 8, immagine 1 di 2 Acer Chromebook C710-2833 SD Card Reader Replacement: passo 8, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    $3.99
    • Use the opening tool to pull the tabs back for the ribbon cable located under the RAM board.
    • Gently pull the ribbon cable out from under the RAM board using the angled tweezers.
  9. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 9, immagine 1 di 2 Acer Chromebook C710-2833 SD Card Reader Replacement: passo 9, immagine 2 di 2
    • Use the opening tool to pry apart the seam around the outer perimeter of the back casing.
    • Pry apart the back casing from the keyboard housing.
  10. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 10, immagine 1 di 2 Acer Chromebook C710-2833 SD Card Reader Replacement: passo 10, immagine 2 di 2
    • Use the opening tool to pull back the tabs on the ribbon cable still connecting the keyboard and the back panel.
    • Use the angled tweezers to gently remove the ribbon cable.
  11. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 11, immagine 1 di 1
    • Lift the keyboard off of the back casing.
  12. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 12, immagine 1 di 1
    • Use a soldering iron to de-solder the nodes shown on the SD Card Reader. There will be 11 nodes above (see the wide red rectangle), and one node on each side (see two red squares).
    • Remove and replace the SD Card Reader.
Conclusione
IUPUI, Team S1-G6, Harley Fall 2018 Membro di IUPUI, Team S1-G6, Harley Fall 2018
IUPUI-HARLEY-F18S1G6
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,047
