Salta al contenuto principale
Acer Chromebook C710-2833 Fan Replacement
Cosa ti serve
  1. Acer Chromebook C710-2833 Fan Replacement, Fan: passo 1, immagine 1 di 1
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 Fan Replacement: passo 2, immagine 1 di 2 Acer Chromebook C710-2833 Fan Replacement: passo 2, immagine 2 di 2
    • Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
    • Once completely unscrewed, carefully lift the cover off.
    • Place the cover and screw safely to the side for now.
  3. Acer Chromebook C710-2833 Fan Replacement: passo 3, immagine 1 di 2 Acer Chromebook C710-2833 Fan Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • Now take your anti-static wrist strap and place it tightly on your wrist.
    • Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
    • The location chosen in the picture is recommended.
  4. Acer Chromebook C710-2833 Fan Replacement: passo 4, immagine 1 di 2 Acer Chromebook C710-2833 Fan Replacement: passo 4, immagine 2 di 2
    • Locate the two 6 mm Phillips #00 screws on the fan port.
    • Unscrew the two screws and place them aside for now.
  5. Acer Chromebook C710-2833 Fan Replacement: passo 5, immagine 1 di 2 Acer Chromebook C710-2833 Fan Replacement: passo 5, immagine 2 di 2
    • Carefully remove the fan from its port. You may need to use a little force as there will be an adhesive on the right side of the fan keeping it in place.
    • Locate the Molex cable connecting the fan to its port in the top left corner.
    • Disconnect the cable.
Conclusione
USF Tampa, Team S1-G6, Nance Fall 2017 Membro di USF Tampa, Team S1-G6, Nance Fall 2017
USFT-NANCE-F17S1G6
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 897
