Salta al contenuto principale
Acer Chromebook C710-2847 Wireless Card Replacement
Cosa ti serve
  1. Acer Chromebook C710-2847 Wireless Card Replacement, Battery: passo 1, immagine 1 di 2 Acer Chromebook C710-2847 Wireless Card Replacement, Battery: passo 1, immagine 2 di 2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Wireless Card Replacement: passo 2, immagine 1 di 2 Acer Chromebook C710-2847 Wireless Card Replacement: passo 2, immagine 2 di 2
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710-2847 Wireless Card Replacement, Acer Chromebook C710-2847 Back Cover Replacement: passo 3, immagine 1 di 1
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
    Bradley,
    If I replace the chrome os Hard drive with one that has a Linux distro already installed will the linux work normally or is there something built in to stop it.
    It's something I do with an old dell I use for checking out distros.
    Regards,
    Jack
    jack martin - Replica
    I guess it's too late to answer this question now, but C710 is not IBM PC-compatible so standard linux distros do not run normally on it without any modifications.
    You can flash a IBM PC-compatible bootloader(coreboot+SEABIOS) on it to run other linux distros.
    cdac1234 -
    Any suggested source for getting the 4 Gb RAM upgrade? Does this RAM have a model number?
    rwells78 -
    What is the hard drive called, or it's specific name, so that I may search around for a replacement, before taking my laptop apart?
    Jennifer Munoz - Replica
    Mine is a Seagate ST320L T020
    Marshall Gates -
    do not so what the second picture shows and leave the battery in!
    brayton1234567 - Replica
  4. Acer Chromebook C710-2847 Wireless Card Replacement: passo 4, immagine 1 di 2 Acer Chromebook C710-2847 Wireless Card Replacement: passo 4, immagine 2 di 2
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
  5. Acer Chromebook C710-2847 Wireless Card Replacement, Wireless Card: passo 5, immagine 1 di 3 Acer Chromebook C710-2847 Wireless Card Replacement, Wireless Card: passo 5, immagine 2 di 3 Acer Chromebook C710-2847 Wireless Card Replacement, Wireless Card: passo 5, immagine 3 di 3
    • Use a spudger or your fingernails to lift up and unclip the two gold connectors on the top of the wireless card.
  6. Acer Chromebook C710-2847 Wireless Card Replacement: passo 6, immagine 1 di 1
    • Unscrew the black #0 3mm Phillips screw at the top right of the wireless card.
  7. Acer Chromebook C710-2847 Wireless Card Replacement: passo 7, immagine 1 di 2 Acer Chromebook C710-2847 Wireless Card Replacement: passo 7, immagine 2 di 2
    • The wireless card will spring up.
    • Pull the wireless card up and out to remove it.
Conclusione
Altre 2 persone hanno completato questa guida.
Bradley Pavy
Membro da: 09/30/13
1.257 Reputazione
6 Guide realizzate
Cal Poly, Team 13-3, Forte Fall 2013 Membro di Cal Poly, Team 13-3, Forte Fall 2013
CPSU-FORTE-F13S13G3
5 Membri
14 Guide realizzate
Un commento
If you replace the original wifi card, how do you get Chrome OS to recognize, or find and download driver for Intel AC 7260 wifi card?
Thanks.
When Ze - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 5,987
