Salta al contenuto principale
Introduzione
If your screen breaks or has dead pixels, the most cost effective solution is to replace the screen.
  1. Place the laptop on a flat surface with the bottom side facing up. Place the tip of a spudger or finger into the hole on the battery release slider.
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Use the spudger to move the slider to the right and hold it there. With the slider held, use your other hand to pull the battery back away from the laptop.
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Open the laptop, keeping the screen on the table. CAUTION: Only use the spudger on the outside of the device. Don't insert it where the bezel meets the screen Use a spudger to unclip the top left and right sides of the bezel. You should feel and hear the clips releasing as you do this.
    • Open the laptop, keeping the screen on the table.
    • CAUTION: Only use the spudger on the outside of the device. Don't insert it where the bezel meets the screen
    • Use a spudger to unclip the top left and right sides of the bezel. You should feel and hear the clips releasing as you do this.
    • Turn the device around 180 degrees, keeping the screen on the table. Use the spudger on the bottom of the screen to unclip the bezel between the hinges.
  4. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  5. Lift the bezel one inch off the top corners of the screen. Gently pull the plastic bezel toward you.
    • Lift the bezel one inch off the top corners of the screen.
    • Gently pull the plastic bezel toward you.
    • Set the bezel aside.
  6. Unscrew the four black #0 3mm Phillips screws holding down the screen. Lift up the small pieces of black tape at the bottom center of the screen near the keyboard.
    • Unscrew the four black #0 3mm Phillips screws holding down the screen.
    • Lift up the small pieces of black tape at the bottom center of the screen near the keyboard.
  7. Lift up the screen from the silver tabs at the top and flip it over to rest on top of the keyboard. Carefully unwrap the narrow black tape from around the ribbon cable connection. Pull off the clear tape from the ribbon cable connection.
    • Lift up the screen from the silver tabs at the top and flip it over to rest on top of the keyboard.
    • Carefully unwrap the narrow black tape from around the ribbon cable connection.
    • Pull off the clear tape from the ribbon cable connection.
  8. Pull out the ribbon cable. Remove any remaining tape holding the screen to the laptop. Remove any remaining tape holding the screen to the laptop.
    • Pull out the ribbon cable.
    • Remove any remaining tape holding the screen to the laptop.
Conclusione
To reassemble your device, follow these instructions in reverse order. Be sure to tape the cable back to the screen to avoid display problems.
Altre 31 persone hanno completato questa guida.
Bradley Pavy
Membro da: 30/09/2013
1.167 Reputazione
6 Guide realizzate
Cal Poly, Team 13-3, Forte Fall 2013 Membro di Cal Poly, Team 13-3, Forte Fall 2013
CPSU-FORTE-F13S13G3
5 Membri
7 Guide realizzate
I am 69 years old and bought myself and 4 grandchildren Acer Chromebooks. I heard the screen messing up was quite common. So when my screen went first, I knew I had to learn to fix it, or spend another small fortune if they all broke down. So here I am. The screen is out..next adventure..putting a new one in. Will return here to do that. Thanks for the site.
Patricia Hadley - Replica
Worked perfectly. Replaced my daughters screen in about 15 minutes. Thank you.
Liam - Replica
Great guide. Didn't realize it was that simple...i'd like a little information on which screen was purchased for this model.
Thanks!
Adam Johnson - Replica
I like it. The link for the screen is dead for me but I will find one.
Spencer Saunders - Replica
Thanks for this. Just repaired 3 laptops for my classroom! Super easy.
Andrew Davis - Replica
I had a chromebook for school which the school bought , and my brother broke it … do these steps really work ?
Jaylin - Replica
Does this really work
Jaylin - Replica
Works well! I work at a school and needed to replace the screens to 10 units. Works great!
Derick Kurpiel - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 66
Tutti i Tempi: 37,558
