Salta al contenuto principale
Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement
Cosa ti serve
  1. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Back Cover: passo 1, immagine 1 di 1
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: passo 2, immagine 1 di 2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: passo 2, immagine 2 di 2
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: passo 3, immagine 1 di 2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: passo 3, immagine 2 di 2
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: passo 4, immagine 1 di 2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: passo 4, immagine 2 di 2
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
  5. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: passo 5, immagine 1 di 3 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: passo 5, immagine 2 di 3 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: passo 5, immagine 3 di 3
    • The Solid State Drive is the blue chip locate right beneath the fan.
    • Unscrew the 3 mm PH00 Phillips head screw located on the left side of the SSD.
  6. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: passo 6, immagine 1 di 2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: passo 6, immagine 2 di 2
    • Grab the top and bottom edges of the SSD and carefully pull it out from the motherboard.
Conclusione
Altre 5 persone hanno completato questa guida.
Un commento
Mine has a positive and neutral wire moving away from the SSD, and removing the chip entirely hasn't impeded operation whatsoever despite me doing it to force developer mode.
Helios Bajammin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 24
Tutti i Tempi: 3,364
