Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide will walk you through replacing the back cover of your Acer Chromebook 15 CB5-571-C09S.
  1. Place the device on a flat surface faced down so that the fan vents are at the top of the device.
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device. Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Use a plastic opening tool to pry open the back cover around the edges of the device. Be careful not to crack or break the back cover of the device.
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Stand the device up with the hinges on top and carefully pull apart the back cover from the device. Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 265
