Salta al contenuto principale
Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement
Cosa ti serve
  1. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement, Wi-Fi Card: passo 1, immagine 1 di 1
    • Place the device on a flat surface with the bottom facing upwards.
  2. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 2, immagine 1 di 2 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 2, immagine 2 di 2
    • Unscrew the eighteen 6 mm screws from bottom of the device using a Phillips #0 screwdriver.
  3. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 3, immagine 1 di 2 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 3, immagine 2 di 2
    • With the plastic opening tool, pry along the edges of the bottom slowly to separate the back cover.
    • Be careful not to damage or crack the back cover of the device.
  4. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 4, immagine 1 di 2 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 4, immagine 2 di 2
    • Carefully remove the back cover.
  5. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 5, immagine 1 di 2 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 5, immagine 2 di 2
    • Locate the Wi-Fi card. It will be white chip beside the motherboard.
    • Remove the 3 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
  6. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 6, immagine 1 di 3 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 6, immagine 2 di 3 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 6, immagine 3 di 3
    • Gently grab the edges of the Wi-Fi card and pull it out from the motherboard.
    • Carefully remove the two coaxial antenna cables that attach the Wi-Fi card to the motherboard. One is black and the other is white.
    • Have your new replacement Wi-Fi card ready to place back in the slot.
Conclusione
Avinesh Mohanaranjan
Membro da: 09/16/21
183 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 24
Tutti i Tempi: 787
