Salta al contenuto principale
Acer Chromebook 15 C910-C453 Trackpad Replacement
Cosa ti serve
  1. Acer Chromebook 15 C910-C453 Trackpad Replacement, Battery: passo 1, immagine 1 di 2 Acer Chromebook 15 C910-C453 Trackpad Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 2, immagine 1 di 1
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 3, immagine 1 di 2 Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 3, immagine 2 di 2
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 4, immagine 1 di 2 Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 4, immagine 2 di 2
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 5, immagine 1 di 1
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Trackpad Replacement, Trackpad: passo 6, immagine 1 di 2 Acer Chromebook 15 C910-C453 Trackpad Replacement, Trackpad: passo 6, immagine 2 di 2
    • Unscrew the seven 6mm Phillips screws located around the trackpad.
  7. Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 7, immagine 1 di 1
    • Lift up the rectangular metal plate at the base.
  8. Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 8, immagine 1 di 2 Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 8, immagine 2 di 2
    • Flip the black bar where the white ribbon is connected to the trackpad upward to unlock it.
    • Gently pull the white ribbon away from the trackpad.
  9. Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 9, immagine 1 di 2 Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 9, immagine 2 di 2
    • Gently lift the trackpad up and pull towards you to remove the trackpad.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S15-G1, Banghart Spring 2017 Membro di Cal Poly, Team S15-G1, Banghart Spring 2017
CPSU-BANGHART-S17S15G1
5 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 411
