Salta al contenuto principale
Acer Chromebook 15 C910-C453 Speakers Replacement
Cosa ti serve
  1. Acer Chromebook 15 C910-C453 Speakers Replacement, Battery: passo 1, immagine 1 di 2 Acer Chromebook 15 C910-C453 Speakers Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Speakers Replacement: passo 2, immagine 1 di 1
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Speakers Replacement: passo 3, immagine 1 di 2 Acer Chromebook 15 C910-C453 Speakers Replacement: passo 3, immagine 2 di 2
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Speakers Replacement: passo 4, immagine 1 di 2 Acer Chromebook 15 C910-C453 Speakers Replacement: passo 4, immagine 2 di 2
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Speakers Replacement: passo 5, immagine 1 di 1
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Speakers Replacement, Speakers: passo 6, immagine 1 di 3 Acer Chromebook 15 C910-C453 Speakers Replacement, Speakers: passo 6, immagine 2 di 3 Acer Chromebook 15 C910-C453 Speakers Replacement, Speakers: passo 6, immagine 3 di 3
    • Before beginning hard drive replacement, the back cover should be taken off and the battery removed to ensure no power is connected.
    • Carefully eject the black ribbon from the white base by squeezing inward at the base and gently pulling backwards.
    • Gently pull black ribbon out.
  7. Acer Chromebook 15 C910-C453 Speakers Replacement: passo 7, immagine 1 di 3 Acer Chromebook 15 C910-C453 Speakers Replacement: passo 7, immagine 2 di 3 Acer Chromebook 15 C910-C453 Speakers Replacement: passo 7, immagine 3 di 3
    • Disconnect the black wires where the speakers are connected to the motherboard by pulling down on both sides with two iFixit Opening Tools.
  8. Acer Chromebook 15 C910-C453 Speakers Replacement: passo 8, immagine 1 di 2 Acer Chromebook 15 C910-C453 Speakers Replacement: passo 8, immagine 2 di 2
    • Gently pull the right speaker, FYHZRF-R, upward, unlatching it from its 2 rubber joints.
    • Repeat with left speaker, FYHZRF-L.
  9. Acer Chromebook 15 C910-C453 Speakers Replacement: passo 9, immagine 1 di 2 Acer Chromebook 15 C910-C453 Speakers Replacement: passo 9, immagine 2 di 2
    • Lift left and right speakers up and untangle the connecting wire from the metal notches.
    • Remove the speakers.
Conclusione
Cal Poly, Team S15-G1, Banghart Spring 2017 Membro di Cal Poly, Team S15-G1, Banghart Spring 2017
CPSU-BANGHART-S17S15G1
5 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 626
