Salta al contenuto principale
Acer Chromebook 15 C910-C453 Solid-State Drive Replacement
Cosa ti serve
  1. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement, Battery: passo 1, immagine 1 di 2 Acer Chromebook 15 C910-C453 Solid-State Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: passo 2, immagine 1 di 1
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: passo 3, immagine 1 di 2 Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: passo 3, immagine 2 di 2
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: passo 4, immagine 1 di 2 Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: passo 4, immagine 2 di 2
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: passo 5, immagine 1 di 1
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement, Solid-State Drive: passo 6, immagine 1 di 2 Acer Chromebook 15 C910-C453 Solid-State Drive Replacement, Solid-State Drive: passo 6, immagine 2 di 2
    • Remove the screw at the left of the drive.
  7. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: passo 7, immagine 1 di 1
    • Remove the drive by pulling it gently to the left.
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team S15-G1, Banghart Spring 2017 Membro di Cal Poly, Team S15-G1, Banghart Spring 2017
CPSU-BANGHART-S17S15G1
5 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 49
Tutti i Tempi: 5,734
