Salta al contenuto principale
Acer Chromebook 15 C910-C453 Fan Replacement
Cosa ti serve
  1. Acer Chromebook 15 C910-C453 Fan Replacement, Battery: passo 1, immagine 1 di 2 Acer Chromebook 15 C910-C453 Fan Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Fan Replacement: passo 2, immagine 1 di 1
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Fan Replacement: passo 3, immagine 1 di 2 Acer Chromebook 15 C910-C453 Fan Replacement: passo 3, immagine 2 di 2
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Fan Replacement: passo 4, immagine 1 di 2 Acer Chromebook 15 C910-C453 Fan Replacement: passo 4, immagine 2 di 2
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Fan Replacement: passo 5, immagine 1 di 1
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Fan Replacement, Fan: passo 6, immagine 1 di 1
    • Unscrew the following Phillips #1 screws:
    • Two black 4mm Phillips screws located on the fan.
    • Four copper 4mm Phillips screws located on the heat sink.
  7. Acer Chromebook 15 C910-C453 Fan Replacement: passo 7, immagine 1 di 1
    • Disconnect the fan from the motherboard by pulling down on the wire connector with two iFixit Opening Tools.
  8. Acer Chromebook 15 C910-C453 Fan Replacement: passo 8, immagine 1 di 1
    • Lift up the fan while unwrapping the black and white wires from around the fan.
    • Do not pull wires off of the motherboard.
    • Remove the fan.
Conclusione
Cal Poly, Team S15-G1, Banghart Spring 2017 Membro di Cal Poly, Team S15-G1, Banghart Spring 2017
CPSU-BANGHART-S17S15G1
5 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 539
