Salta al contenuto principale
Acer Chromebook 15 C910-C453 Battery Replacement
Cosa ti serve
  1. Acer Chromebook 15 C910-C453 Battery Replacement, Battery: passo 1, immagine 1 di 2 Acer Chromebook 15 C910-C453 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Battery Replacement: passo 2, immagine 1 di 1
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Battery Replacement: passo 3, immagine 1 di 2 Acer Chromebook 15 C910-C453 Battery Replacement: passo 3, immagine 2 di 2
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Battery Replacement: passo 4, immagine 1 di 2 Acer Chromebook 15 C910-C453 Battery Replacement: passo 4, immagine 2 di 2
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Battery Replacement: passo 5, immagine 1 di 1
    • Remove the battery.
Conclusione
Altre 8 persone hanno completato questa guida.
Cal Poly, Team S15-G1, Banghart Spring 2017 Membro di Cal Poly, Team S15-G1, Banghart Spring 2017
CPSU-BANGHART-S17S15G1
5 Membri
12 Guide realizzate
1Commento della guida
Jacob, WELL DONE. I have an Acer 15 C910-C451 that was driving me nuts. It would hold a battery charge but only up to 17% then drain fairly rapidly duing use. It didn’t make sense that a battery would have a set of bad cells but that is probably exactly what was the problem. So new battery in hand and a set of tools designed not to harm the case I followed your instructions to the letter. BINGO ! At this moment the unit is charging from a start of 87% it is now at 96% and climbing. Thanks for the detailed pics of the process.
Thomas Revell - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 10,283
