Salta al contenuto principale
Acer Chromebook 14 CB3-431-C7EX Trackpad Replacement
Cosa ti serve
  1. Acer Chromebook 14 CB3-431-C7EX Trackpad Replacement, Battery: passo 1, immagine 1 di 3 Acer Chromebook 14 CB3-431-C7EX Trackpad Replacement, Battery: passo 1, immagine 2 di 3 Acer Chromebook 14 CB3-431-C7EX Trackpad Replacement, Battery: passo 1, immagine 3 di 3
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • There are several clips holding the cover in place.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Trackpad Replacement: passo 2, immagine 1 di 3 Acer Chromebook 14 CB3-431-C7EX Trackpad Replacement: passo 2, immagine 2 di 3 Acer Chromebook 14 CB3-431-C7EX Trackpad Replacement: passo 2, immagine 3 di 3
    • Use a spudger to disconnect the battery's connector from the motherboard. The connector should slide out toward the battery.
    • Be sure to remove the connector evenly from the port.
  3. Acer Chromebook 14 CB3-431-C7EX Trackpad Replacement: passo 3, immagine 1 di 2 Acer Chromebook 14 CB3-431-C7EX Trackpad Replacement: passo 3, immagine 2 di 2
    • Use a Phillips #0 screwdriver to unscrew the two 5.5mm screws from the battery housing.
  4. Acer Chromebook 14 CB3-431-C7EX Trackpad Replacement: passo 4, immagine 1 di 1
    • While lifting the connector side of the battery, slide the battery towards the center of the laptop.
    • Be mindful of the tabs on the bottom of the battery housing (shown in picture). These need to be underneath slots when reinserting the battery back into the laptop.
    • Remove the battery from the laptop.
  5. Acer Chromebook 14 CB3-431-C7EX Trackpad Replacement, Trackpad: passo 5, immagine 1 di 2 Acer Chromebook 14 CB3-431-C7EX Trackpad Replacement, Trackpad: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to set aside the electric tape (black) and the ground tape (tan) to reveal the trackpad screws and ribbon connector.
  6. Acer Chromebook 14 CB3-431-C7EX Trackpad Replacement: passo 6, immagine 1 di 3 Acer Chromebook 14 CB3-431-C7EX Trackpad Replacement: passo 6, immagine 2 di 3 Acer Chromebook 14 CB3-431-C7EX Trackpad Replacement: passo 6, immagine 3 di 3
    • Use a spudger to disconnect the connector that connects the trackpad to the motherboard. Once the locking tab of the ZIF connector is flipped up, the ribbon cable should slide out toward the motherboard.
    • Be sure to remove the connector evenly from the port, as the ribbon connector may be fragile.
  7. Acer Chromebook 14 CB3-431-C7EX Trackpad Replacement: passo 7, immagine 1 di 2 Acer Chromebook 14 CB3-431-C7EX Trackpad Replacement: passo 7, immagine 2 di 2
    • Use a Phillips #0 screwdriver to unscrew the three 2mm screws from the top of the trackpad.
  8. Acer Chromebook 14 CB3-431-C7EX Trackpad Replacement: passo 8, immagine 1 di 2 Acer Chromebook 14 CB3-431-C7EX Trackpad Replacement: passo 8, immagine 2 di 2
    • Remove the trackpad out from its housing by first sliding it towards the keyboard and then down towards the screen.
    • Be mindful of the two tabs that secure the bottom of the trackpad.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Thanks for this guide. You have helped a non-techie look oh so impressive with his repair skills!
Nigel Warman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 373
