Salta al contenuto principale
Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement
Cosa ti serve
  1. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement, Back Cover: passo 1, immagine 1 di 3 Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement, Back Cover: passo 1, immagine 2 di 3 Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement, Back Cover: passo 1, immagine 3 di 3
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: passo 2, immagine 1 di 1
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: passo 3, immagine 1 di 2 Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: passo 3, immagine 2 di 2
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: passo 4, immagine 1 di 1
    • Lift off the back cover.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 608
