Salta al contenuto principale
Acer Aspire V5-591G-75KE Memory Modules Replacement
Cosa ti serve
  1. Acer Aspire V5-591G-75KE Memory Modules Replacement, Acer Aspire V5-591G-75KE Disassembly: passo 1, immagine 1 di 3 Acer Aspire V5-591G-75KE Memory Modules Replacement, Acer Aspire V5-591G-75KE Disassembly: passo 1, immagine 2 di 3 Acer Aspire V5-591G-75KE Memory Modules Replacement, Acer Aspire V5-591G-75KE Disassembly: passo 1, immagine 3 di 3
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Memory Modules Replacement: passo 2, immagine 1 di 2 Acer Aspire V5-591G-75KE Memory Modules Replacement: passo 2, immagine 2 di 2
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Memory Modules Replacement: passo 3, immagine 1 di 2 Acer Aspire V5-591G-75KE Memory Modules Replacement: passo 3, immagine 2 di 2
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Memory Modules Replacement: passo 4, immagine 1 di 3 Acer Aspire V5-591G-75KE Memory Modules Replacement: passo 4, immagine 2 di 3 Acer Aspire V5-591G-75KE Memory Modules Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
  5. Acer Aspire V5-591G-75KE Memory Modules Replacement, Memory Modules: passo 5, immagine 1 di 3 Acer Aspire V5-591G-75KE Memory Modules Replacement, Memory Modules: passo 5, immagine 2 di 3 Acer Aspire V5-591G-75KE Memory Modules Replacement, Memory Modules: passo 5, immagine 3 di 3
    • Locate the memory modules at the bottom right quadrant of the motherboard. The two memory modules are slightly stacked on top of each other.
    • Using both hands, pull the clasps away simultaneously in order to release the memory modules.
    • Once the clasps have been released, each memory module will spring up.
  6. Acer Aspire V5-591G-75KE Memory Modules Replacement: passo 6, immagine 1 di 2 Acer Aspire V5-591G-75KE Memory Modules Replacement: passo 6, immagine 2 di 2
    • To remove the top memory module, lift the module slightly up and pull away.
    • Repeat the previous step to remove the bottom memory module.
    • Take note of the pins on the bottom of each memory module and make sure they line up with the slots when re-installing the memory modules. Once aligned and inserted, simply push the memory module down to lock it in place.
Conclusione
UW Tacoma, Team S3-G5, Liner Fall 2017 Membro di UW Tacoma, Team S3-G5, Liner Fall 2017
UWT-LINER-F17S3G5
4 Membri
18 Guide realizzate
Un commento
Great job on the guide! looks very professional!
Aiden - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 489
