Salta al contenuto principale
Acer Aspire V5-591G-75KE Hard Drive Replacement
Cosa ti serve
  1. Acer Aspire V5-591G-75KE Hard Drive Replacement, Acer Aspire V5-591G-75KE Disassembly: passo 1, immagine 1 di 3 Acer Aspire V5-591G-75KE Hard Drive Replacement, Acer Aspire V5-591G-75KE Disassembly: passo 1, immagine 2 di 3 Acer Aspire V5-591G-75KE Hard Drive Replacement, Acer Aspire V5-591G-75KE Disassembly: passo 1, immagine 3 di 3
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Hard Drive Replacement: passo 2, immagine 1 di 2 Acer Aspire V5-591G-75KE Hard Drive Replacement: passo 2, immagine 2 di 2
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Hard Drive Replacement: passo 3, immagine 1 di 2 Acer Aspire V5-591G-75KE Hard Drive Replacement: passo 3, immagine 2 di 2
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Hard Drive Replacement: passo 4, immagine 1 di 3 Acer Aspire V5-591G-75KE Hard Drive Replacement: passo 4, immagine 2 di 3 Acer Aspire V5-591G-75KE Hard Drive Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
  5. Acer Aspire V5-591G-75KE Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 3 Acer Aspire V5-591G-75KE Hard Drive Replacement, Hard Drive: passo 5, immagine 2 di 3 Acer Aspire V5-591G-75KE Hard Drive Replacement, Hard Drive: passo 5, immagine 3 di 3
    • Using the plastic tabs, lift the hard drive slightly and pull to the left.
    • Remove the rubber mounting brackets from the hard drive.
    • If you are replacing your hard drive with a new one, please note you will need to reuse the rubber mounting brackets in order to secure it in place.
Conclusione
UW Tacoma, Team S3-G5, Liner Fall 2017 Membro di UW Tacoma, Team S3-G5, Liner Fall 2017
UWT-LINER-F17S3G5
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,132
