Salta al contenuto principale
Acer Aspire V5-591G-75KE Disassembly
Cosa ti serve
  1. Acer Aspire V5-591G-75KE Disassembly, Acer Aspire V5-591G-75KE Disassembly: passo 1, immagine 1 di 3 Acer Aspire V5-591G-75KE Disassembly, Acer Aspire V5-591G-75KE Disassembly: passo 1, immagine 2 di 3 Acer Aspire V5-591G-75KE Disassembly, Acer Aspire V5-591G-75KE Disassembly: passo 1, immagine 3 di 3
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Disassembly: passo 2, immagine 1 di 2 Acer Aspire V5-591G-75KE Disassembly: passo 2, immagine 2 di 2
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Disassembly: passo 3, immagine 1 di 2 Acer Aspire V5-591G-75KE Disassembly: passo 3, immagine 2 di 2
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Disassembly: passo 4, immagine 1 di 3 Acer Aspire V5-591G-75KE Disassembly: passo 4, immagine 2 di 3 Acer Aspire V5-591G-75KE Disassembly: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
Conclusione
Tasier Hagler
Membro da: 10/18/17
428 Reputazione
4 Guide realizzate
UW Tacoma, Team S3-G5, Liner Fall 2017 Membro di UW Tacoma, Team S3-G5, Liner Fall 2017
UWT-LINER-F17S3G5
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 33
Tutti i Tempi: 4,121
