Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
Acer Aspire - V5-572, V5-572G
We will show you how to open the Laptop and install a new RAM Module.
Panoramica Video
  1. Switch-off the Laptop.
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. If there is a plastic storage tray in the laptop, remove it.
    • If there is a plastic storage tray in the laptop, remove it.
  3. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Starting from the SD Memory Card hole, start prying between the top and bottom cases. Use plastic tools to avoid damaging the cover. Remove the bottom case.
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  5. Disconnect the battery immediately for a safer repair.
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  6. This model have 1x Memory Slot. You can upgrade your laptop with SODIMM DDR3 ram at 1333 or 1600. You can upgrade your laptop with SODIMM DDR3 ram at 1333 or 1600.
    • This model have 1x Memory Slot.
    • You can upgrade your laptop with SODIMM DDR3 ram at 1333 or 1600.
Conclusione
Altre 4 persone hanno completato questa guida.
ZFix
Membro da: 09/12/2013
171.991 Reputazione
307 Guide realizzate
Master Techs Membro di Master Techs
Community
294 Membri
935 Guide realizzate
Hi,
While adding an extra RAM to the module in Aspire V5-472, I forgot to disconnnect the battery first.
I first tried 4 GB RAM compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. When that didn't work, I checked again.
Next time I disconnected the battery, and repeated the process with 2 GB RAM, compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. The RAM was still not discovered. None of the RAMs were detected.
Hope I haven't fried the RAM Module itself.
Please help.
Indi Shukla - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 136
Tutti i Tempi: 16,101
