Salta al contenuto principale
Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade
Cosa ti serve
Panoramica Video
  1. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Bottom Cover: passo 1, immagine 1 di 1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: passo 2, immagine 1 di 1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: passo 3, immagine 1 di 3 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: passo 3, immagine 2 di 3 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: passo 3, immagine 3 di 3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: passo 4, immagine 1 di 1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Memory (RAM): passo 5, immagine 1 di 3 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Memory (RAM): passo 5, immagine 2 di 3 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Memory (RAM): passo 5, immagine 3 di 3
    • This model have 1x Memory Slot.
    • You can upgrade your laptop with SODIMM DDR3 ram at 1333 or 1600.
Conclusione
Altre 6 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.182 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.521 Guide realizzate
Un commento
Hi,
While adding an extra RAM to the module in Aspire V5-472, I forgot to disconnnect the battery first.
I first tried 4 GB RAM compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. When that didn't work, I checked again.
Next time I disconnected the battery, and repeated the process with 2 GB RAM, compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. The RAM was still not discovered. None of the RAMs were detected.
Hope I haven't fried the RAM Module itself.
Please help.
Indi Shukla - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 69
Tutti i Tempi: 22,721
