Salta al contenuto principale
Acer Aspire V5-572, V5-572G Mainboard Replacement
Cosa ti serve
Panoramica Video
  1. Acer Aspire V5-572, V5-572G Mainboard Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Mainboard Replacement: passo 2, immagine 1 di 1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Mainboard Replacement: passo 3, immagine 1 di 3 Acer Aspire V5-572, V5-572G Mainboard Replacement: passo 3, immagine 2 di 3 Acer Aspire V5-572, V5-572G Mainboard Replacement: passo 3, immagine 3 di 3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G Mainboard Replacement: passo 4, immagine 1 di 1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Mainboard Replacement, Battery: passo 5, immagine 1 di 1
    • Remove the single Phillips 0 screw securing the battery.
  6. Acer Aspire V5-572, V5-572G Mainboard Replacement: passo 6, immagine 1 di 1
    • Remove the battery
  7. Acer Aspire V5-572, V5-572G Mainboard Replacement, HDD: passo 7, immagine 1 di 3 Acer Aspire V5-572, V5-572G Mainboard Replacement, HDD: passo 7, immagine 2 di 3 Acer Aspire V5-572, V5-572G Mainboard Replacement, HDD: passo 7, immagine 3 di 3
    • Disconnect the SATA Cable from the Mother Board.
    • Take out the HDD and remove the SATA cable from it.
    • Now you can change / upgrade your HDD.
  8. Acer Aspire V5-572, V5-572G Mainboard Replacement, Wi-Fi half mini PCIe card: passo 8, immagine 1 di 3 Acer Aspire V5-572, V5-572G Mainboard Replacement, Wi-Fi half mini PCIe card: passo 8, immagine 2 di 3 Acer Aspire V5-572, V5-572G Mainboard Replacement, Wi-Fi half mini PCIe card: passo 8, immagine 3 di 3
    • Remove 1x screw and disconnect the two antenna coaxial cables.
    • Remove the Wi-Fi card from the slot.
  9. Acer Aspire V5-572, V5-572G Mainboard Replacement, Cooling / Fan System: passo 9, immagine 1 di 2 Acer Aspire V5-572, V5-572G Mainboard Replacement, Cooling / Fan System: passo 9, immagine 2 di 2
    • Disconnect the Fan cable.
    • Remove the three screws from the CPU cooler and one from the Fan module.
    • When you change the Cooling system, you must clean the processor from old thermal compound and put new.
  10. Acer Aspire V5-572, V5-572G Mainboard Replacement, Mainboard: passo 10, immagine 1 di 3 Acer Aspire V5-572, V5-572G Mainboard Replacement, Mainboard: passo 10, immagine 2 di 3 Acer Aspire V5-572, V5-572G Mainboard Replacement, Mainboard: passo 10, immagine 3 di 3
    • Disconnect one by one:
    • LCD Display flex cable
    • DC Jack cable
    • USB Board flex cable
    • Touch pad flex cable
    • Keyboard flex cable
  11. Acer Aspire V5-572, V5-572G Mainboard Replacement: passo 11, immagine 1 di 3 Acer Aspire V5-572, V5-572G Mainboard Replacement: passo 11, immagine 2 di 3 Acer Aspire V5-572, V5-572G Mainboard Replacement: passo 11, immagine 3 di 3
    • Disconnect the Loudspeakers and the Microphone cables.
    • Remove 6x Phillips screws, 3x from the Main board and 3x from the hinge.
    • Open a little the laptop to open the hinge.
    • By hand, open the hinge to the end.
  12. Acer Aspire V5-572, V5-572G Mainboard Replacement: passo 12, immagine 1 di 3 Acer Aspire V5-572, V5-572G Mainboard Replacement: passo 12, immagine 2 di 3 Acer Aspire V5-572, V5-572G Mainboard Replacement: passo 12, immagine 3 di 3
    • Carefully remove the the Main board.
Conclusione
ZFix
Membro da: 12/09/13
191.278 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.528 Guide realizzate
Un commento
where did you find your motherboard replacement? Or whats model is it? I need to replace my mb but cant find any online for sale.
Ruby - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 23
Tutti i Tempi: 4,646
