Salta al contenuto principale
Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement
Cosa ti serve
Panoramica Video
  1. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: passo 2, immagine 1 di 1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: passo 3, immagine 1 di 3 Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: passo 3, immagine 2 di 3 Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: passo 3, immagine 3 di 3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: passo 4, immagine 1 di 1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Battery: passo 5, immagine 1 di 1
    • Remove the single Phillips 0 screw securing the battery.
  6. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: passo 6, immagine 1 di 1
    • Remove the battery
  7. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Loudspeakers and Microphone: passo 7, immagine 1 di 3 Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Loudspeakers and Microphone: passo 7, immagine 2 di 3 Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Loudspeakers and Microphone: passo 7, immagine 3 di 3
    • Disconnect the Loudspeakers cable.
    • There are two modules with loudspeakers, connected with one wire.
    • Unscrew the screws and remove the Loudspeaker modules together with the cable.
Conclusione
ZFix
Membro da: 12/09/13
191.182 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.521 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 30
Tutti i Tempi: 2,159
