Introduzione
How to disassemble the laptop and change the Cooling system.
Switch-off the Laptop.
  • Switch-off the Laptop.
  • Remove 17x Philips screws.
Aggiungi Commento
Start opening from the SD Memory Card hole
  • Start opening from the SD Memory Card hole
  • Use plastic tools to avoid damaging the cover.
Love the tutorial man...but this is the most moronic thing I've ever seen...you can take batery out of laptop 15 years old in a flash, while here you have to disassemble the whole %#*@ laptop...only idiots can come up with something like that
razbojnikkuro - Replica
  • Before doing anything, disconnect the battery.
Aggiungi Commento
  • Disconnect the Fan cable.
  • Remove the three screws from the CPU cooler and one from the Fan module.
  • When you change the Cooling system, you must clean the processor from old thermal compound and put new.
Aggiungi Commento
Conclusione
ZFix
Membro da: 09/12/2013
156.419 Reputazione
304 Guide realizzate
Master Techs Membro di Master Techs
Community
277 Membri
747 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 31
Tutti i Tempi: 1,610
